Smart light bulb – control from your phone or tablet
White and coloured bulb – choose from 16 million shades
Standalone light with a 25,000 hour lifespan
Schedule a timer to turn lights on automatically
Dim the brightness to match your mood
Product Description | Philips Hue Impress Slim - wall lamp - LED - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - black (pack of 2) | Product Type | Wall lamp | Light Source Type | LED | Packaged Quantity | 2 (specifications are for single item) | Dimmer | Yes | Colour | Black | Wattage | 8 W | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 710 - 1180 lumens | Platform | Hue | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Features | Weatherproof, outdoor usage, LowVolt system |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 8 W |
Colour Rendering Index | 80 |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Miscellaneous | |
Product Material | Glass |
Body Colour | Black |
Compliant Standards | IP44 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 12 cm |
Depth | 14.1 cm |
Height | 24 cm |
Shipping Dimensions (WxDxH) / Weight | 14.9 cm x 19.4 cm x 33.6 cm / 2 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
