Philips Hue Iris Clear - Single
£69.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Control from your iOS and Android smart devices
  • Connect up to 50 bulbs and lamps
  • Create light settings based on your favorite picture
  • Use light to help you through your sleeping routine
  • Enjoy dynamic light effects synced to your moment
  • Set lights to turn on and off when you're away from home
  • Fits with every interior perfectly
  • Freedom of placement; blends seamlessly with your interiors
  • Vary your ambience with colored light
  • Just the right amount of light
Product codes
Light your room to set the mood with the unique Friends of Hue LivingColors Iris, from Philips. Designed to work with Philips Hue systems, this wireless-enabled mood light connects to your Wi-Fi to allow you you to control the atmosphere in your room through the Philips Hue app for iOS and Android. Hue lamps and light bulbs can be grouped together so you can set the mood in a room in one go, with up to 50 lights on one network.
Colour your life
With 16 million colour variations to choose from, you can set Iris to the mood that suits you, so you can wash your walls with a blue ocean glow or illuminate a favourite feature. Colours can be saved as 'Scenes', so you can revisit your favourites, or you can choose from the available presets. These 'light recipes' have been proven to create the perfect atmosphere for your needs. The 'Reading' recipe is ideal for curling up with a book, while 'Relax' provides a soothing glow. 'Concentrate' will help you stay alert when working, while 'Energise' bathes you in vibrant lights to revitalise you.
Programmable
Iris works as more than just a colourful lamp. It can be tailored to your life, with alarms, timers and alerts, so you can set Hue to wake you up with a soft sunrise glow, or to turn all of your Hue lights off at bedtime. Hue lights can flash at you to let you know when your food is ready to come out of the oven, or to let you know when your favourite TV show is starting. You can set your lights to come on when you're away, to deter thieves, or control them remotely via the portal, from anywhere in the world. Geofencing technology can be used to turn your Hue lights on as you enter the door. Hue can even be linked to data feeds via the IFTTT (If This Then That) service, to give you a visual alert when you get an important email or when the weather changes.
Apps to help you unlock more
With additional iOS and Android apps, you can get even more out of your Hue. Ambilight+hue for both iOS and Android works with Philips Ambilight TVs (2011 model or newer, type number 6 or higher in xxPFLxxx6) to match the mood in your living room to the scenes on TV, creating a more immersive experience. Ambify for iOS and hue Disco for Android make Hue react to music, providing you with an instant dance floor.
Philips Hue Iris - decoration lamp - LED
Decoration lamp
Light Bulb Type
LED
Dimmer
Clear
Wattage
10 W
Luminous Power
210 lumens
Beam Angle
120 degree(s)
AC 100 - 240 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue Iris Clear...
£69.99
