Personalize your outdoor space with a Philips Hue outdoor lightstrip. With its perfectly diffused glow, the flexible outdoor LED strip is ideal for direct and indirect lighting.
Product Description | Philips Hue White and Color Ambiance - light strip - LED - 19 W - warm white to cool daylight - 2000-6500 K - multicolour | Product Type | Light strip | Light Source Type | LED | Colour | Multicolour | Wattage | 19 W | Colour of Illumination | Warm white to cool daylight | Colour Temperature | 2000-6500 K | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue |
General | |
Features | Double insulated, weatherproof, outdoor usage, flexible, ZigBee Light Link, 16 million changeable colours, diffused light effect, power on/off timer |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 19 W |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | Voice control, built-in diffuser |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Silicone |
Body Colour | Multicolour |
Included Accessories | Power supply, power plug |
Package | Box |
Compliant Standards | IP67 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 11 mm |
Height | 20 mm |
Length | 2 m |
Weight | 950 g |
Shipping Dimensions (WxDxH) / Weight | 210 mm x 96 mm x 210 mm / 1.17 kg |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
