Philips Hue LightStrip Plus Extension Set
FREE DELIVERY
£17.98
Delivery:
Standard: 1-3 working days
Key features
  • Turn on your imagination
  • High light output for functional and decorative use
  • Turn on your moments
  • Energize, concentrate, read and relax with light
  • Turn on your peace of mind
  • Control your lights from anywhere
  • Set light schedules for easy home automation
  • Type: Light strip
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: Clearance
Product codes
Light up your home with the Philips Hue Lightstrip Plus 1m Extension Set. The most most flexible light source imaginable, get creative and use it to set the mood in a room - highlighting architectural features with smooth, indirect light. Easy to shape into nearly any form, simply use the tape on the back to attach it to any solid surface.
Simply start with the Philips Hue Lightstrip Plus and extend it by up to ten metres with additional 1 m extension strips.
Highlights
  • One-metre extension for Philips Hue Lightstrip Plus
  • Connect wirelessly to the Philips Hue bridge to control from your iPhone, iPad or iPod touch
  • Create a personal lighting scheme in each room
  • Up to 16 million colours
  • 1600 lumen output
  • Adheres to any solid surface
  • Shape, bend, and cut to size
You can shape the strip in nearly any form and use the tape on the back to attach it to any solid surface.
What's in the box?
  • Philips Hue Lightstrip Plus 1m Extension Set
  • Quick Start guide
  • Legal manual
  • Note: This product requires the Philips HUE bridge to function.
Product Description Philips Hue Plus extension - light strip - LED
Product Type Light strip
Light Source Type LED
Dimmer Yes
Built-in LED Energy Efficiency Class A
Colour of Illumination 16 million colours
Luminous Power 800 lumens
Voltage Required AC 220 - 240 V
Frequency Required 50 - 60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue LightStrip...
£17.98
