Philips Hue LightStrips Plus 1m Extension UK/EU *V2
Select:
  • 1m
Product codes
Please note that to use this you must also have the Lightstrips Plus 2m (our QL CHZ4) BEFORE you can add the 1m Extension
Colour your world with light
The Philips friends of hue LightStrips starter kit lets you create ideal mood lighting at home with your smartphone or devices. Create that extra dimension on architectural features or simply behind objects. Bend, shape or flex — it's your choice.
Wireless connectivity
  • Control from your iOS and Android smart devices.
  • Always up to date.
  • Connect up to 50 bulbs and lamps.
Match your light to the moment
  • Create light settings based on your favourite picture.
  • Use light to help you through your sleeping routine.
  • Enjoy dynamic light effects synced to your moment.
  • Set lights to turn on and off when you're away from home.
Fits with every interior perfectly
  • Ultimate flexibility in placement.
  • Easy to cut. For maximum freedom.
  • Vary your ambience with coloured light.
  • Just the right amount of light.
Control from smart devices
The Philips hue bridge included in this starter kit lets you control your lights wirelessly from anywhere in your house. Be it from the living room, the dining table or your bedroom, your smart device can control any light connected to the bridge.
Create your own light settings
Use your favourite picture to generate the perfect colour scene for special occasions. Go back in time and relive those moments by uploading your own picture and tuning the lights accordingly. Add up to 50 lights to every setting, and recall with a simple tap of the finger.
Light dynamics
The hue ecosystem is fully open for developers. There are an ever-growing number of applications being developed for hue within this community. This has resulted in creative and dynamic lighting schemes opening possibilities of syncing your lights to your favourite music, to get the party kicking.
Upgradeable
Philips hue is based on ZigBee, a low-power, safe, and reliable technology to control your lights. We are constantly striving to make improvements and add new features to the system. Updates to both software and firmware are done wirelessly and seamlessly directly to your Friends of hue product.
Timer function
The timer function not only lets you pre-set what time your Friends of hue product comes on, for light when you arrive home in the evening, but also lets you change your lights gradually over time. Use it to turn your Friends of hue product into your wake-up light. Pre-set it to increase the brightness gradually to bring you out of your sleep softly and gently compared with the sudden beep or ring of a conventional alarm clock. At night, you can pre-set the timer to turn your lights off gradually to help you fall asleep naturally.
Safety and security
Make it look like you are at home even when you are away! With online access and at the tap of your smart device's menu screen, you can now control your home lighting. Convenience and peace of mind.
Expand your ecosystem
You can connect up to 50 bulbs or lamps to your Philips hue bridge. Simply begin with any of the available starter kits and start adding Philips hue bulbs or Philips Friends of hue products in any combination. With a tap of your finger, you can now control any connected lighting in your home.
Adheres to any solid surface
Bend, shape and fix your Friends of hue LightStrips to highlight furniture and create complete new light effects. Thanks to the integrated adhesive tape of the Friends of Hue LightStrips, it's easy to install the product anywhere and on any piece of furniture.
Philips Hue Lightstrip Plus - light strip - LED
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue LightStrip...
