Philips Hue LightStrips Plus UK/EU
BUNDLES
SEE BUNDLE DEALS FOR FREE EXTENSION SET
£69.99
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flexible light, extendable and cuttable to size
  • High light output for fuctional and decorative use
  • Play with warm to cool white light and 16 million colors
  • Sync your Philips Hue lights with movies and music
  • Energize, concentrate, read and relax with light
  • Control your lights from anywhere
  • Set light schedules for easy home automation
  • Control your lights, your way
  • Easy, reliable and future proof system
Product codes
Bundle deals (1)
FREE LIGHTSTRIP EXTENSION
= £69.99
Save £19.99
The most flexible light source imaginable. Shape it and attach it to any solid surface. Connect it to the Philips Hue Bridge and control it with your smart phone or tablet.
Ultimate flexibility: shape, bend and extend
Philips Hue Lightstrip Plus is the most flexible light source imaginable. You can shape the strip into almost any form and use the adhesive tape on the back to attach it to any solid surface. If needed, you can cut your Philips Hue Lightstrip Plus to size at the scissor markings. Integrate Philips Hue Lightstrip Plus onto furniture, in coves, under kitchen cabinets or highlight architectural features with smooth, indirect light. Philips Hue Lightstrip Plus is the most versatile and robust light source that will bring your room to life.
Extendible up to 10 metres
Extend your Philips Hue Lightstrip Plus by up to 10 metres by adding 1-metre extensions to cover larger surfaces and enable wider applications. From bright cove lighting to ambient navigation light in your hallway or stairs, anything is possible. Philips Hue lightstrip plus gives you full colour consistency from the first to the last extension.
High light output: 1600 lumen
With a high output of 1,600 lumen and light coverage over its total length, hue Lightstrip Plus gives enough light to be used both as a decorative and functional light source.
Requires a Philips Hue bridge
Connect your Philips Hue lights with the bridge to control your lights from your smartphone or tablet via the Philips Hue app.
Be creative with 16 million colours
Play with light and choose from 16 million colours to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favourite photo and relive that special moment with splashes of light. Save your favourite light settings and recall them whenever you want with the tap of a finger
Sync lights with music and films
Extend your TV viewing experience to the whole room or sync light to your favourite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
Product Description Philips Hue Plus - light strip - LED
Product Type Light strip
Light Bulb Type LED
Dimmer Yes
Colour of Illumination 16 million colours
Luminous Power 1600 lumens
Voltage Required AC 220 - 240 V
Frequency Required 50 - 60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue LightStrip...
£69.99
