Enhance your outdoor space and create the right atmosphere for any occasion with Lily spot lights.
Product Description | Philips Hue White and Color Ambiance Lily - garden spot light set - LED x 3 - 16 million colours - 2000-6500 K - black | Product Type | Garden spot light set | Recommended For | Garden, patio | Light Source Type | 3 x LED | Dimmer | Yes | Cable Length | 50 cm | Colour | Black | Energy Efficiency Class | G | Colour of Illumination | 16 million colours | Colour Temperature | 2000-6500 K | Intelligent Assistant | Siri, Google Assistant, Alexa | Platform | Apple HomeKit, Hue | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Waterproof | Yes |
Features | Weatherproof, outdoor usage, protection class III, dustproof, app-controlled, voice control, LowVolt system |
Light Source | |
Type | 3 x LED |
Built-in LED Lamp | Yes |
Colour Rendering Index | 80 |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Miscellaneous | |
Product Material | Aluminium, synthetics |
Body Colour | Black |
Included Accessories | Mounting kit, power supply |
Compliant Standards | IP65 |
Warranty | 2 years |
Dimensions & Weight | |
Dimensions & Weight Details | Spotlight - width: 7 cm x depth: 8.4 cm x height: 19.4 cm - 430 g , Spotlight - width: 11.2 cm x depth: 11.2 cm x height: 19 cm - 1.4 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
