We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With the Philips Hue White Ambiance spot, you can enjoy natural white light that helps you to wake up, energize, concentrate, read and relax. A high-quality spot, built to last with attention to detail.
Product Description | Philips Hue White ambiance Milliskin - recessed spot light - LED spot light bulb - GU10 - 5.7 W - warm to cool white light - 2200-6500 K - white (pack of 3) | Product Type | Recessed spot light | Recommended For | Kitchen, living room, bedroom, workspace | Light Source Type | LED spot light bulb | Packaged Quantity | 3 (specifications are for single item) | Supported Light Bulbs Qty | 1 | Dimmer | Yes | Colour | White | Socket Type | GU10 | Wattage | 5.7 W | Colour of Illumination | Warm to cool white light | Colour Temperature | 2200-6500 K | Luminous Power | 350 lumens | Beam Angle | 40 degree(s) | Intelligent Assistant | Google Assistant, Alexa | Platform | Hue | Communications Technology | Bluetooth | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Position Adjustments | Swivel head |
Dimmer | Yes |
Features | Double insulated, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, voice control |
Light Source | |
Wattage | 5.7 W |
Colour Rendering Index | 80 |
Lifetime | 15000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Miscellaneous | |
Product Material | Synthetics |
Body Colour | White |
Package | Box |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 9 cm |
Weight | 198 g |
Dimensions & Weight Details | Hole cut-out - width: 7 cm x depth: 10 cm |
Shipping Dimensions (WxDxH) / Weight | 21.9 cm x 10 cm x 20.9 cm / 856 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
