Marketing description is not available.
Product Description | Philips Hue White and Color Ambiance Large Gradient Play - light bar - LED - tube - white | Product Type | Light bar - tube | Light Source Type | LED | Light Cover Type | Diffuser | Dimmer | Yes | Cable Length | 2 m | Colour | White | Luminous Power | 1800 lumens | Voltage Required | AC 100 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Product Type | Light bar |
Shape | Tube |
Dimmer | Yes |
Features | Protection class III, replaceable lighting module, Hue Sync technology, 60" TVs compatible |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Required |
Hub Compatibility | Philips Hue Bridge |
Miscellaneous | |
Product Material | Aluminium |
Body Colour | White |
Included Accessories | Power supply |
Package | Box |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Depth | 3.1 cm |
Height | 3.4 cm |
Length | 137.7 cm |
Shipping Dimensions (WxDxH) / Weight | 12 cm x 141.6 cm x 10 cm / 1.743 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
