Experience the thrill of the cinema at home with the Philips Hue Play Gradient Lightstrip. Get multiple colours of light that react to the content on your screen. Attach to 55" to 65" wall-mounted or standing TVs with the included mounts.
Seamlessly Blend Colours
Get a seamless blend of multiple colours of light at the same time in a single LED strip. The colours flow together naturally, casting light against the wall to showcase a unique effect behind your TV.
Surround Lighting Effects
Experience the magic of surround lighting! With 45-degree light projection, the Play Gradient Lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience. *Requires the Philips Hue Play HDMI sync box and Hue Bridge (sold separately).
Game-changing Home Entertainment
Philips Hue is the only smart lighting brand to easily sync your colour-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colourful full-room experience.
Easy Installation
The Philips Hue Play Gradient Lightstrip is specially designed for television entertainment. The LED strip comes in three sizes, fitting TVs of 55" and larger, and includes mounting brackets to make installation quick and easy.
Hue Sync and Hue Bridge Required
The Philips Hue Play gradient Lightstrip requires the Philips Hue Play HDMI sync box, Hue Sync mobile app and a Hue Bridge. The Bridge also allows you to add up to 50 lights and accessories throughout your entire home, create timers and routines, and control your lights from anywhere – inside or outside your home – with the Hue app. The Philips Hue Play HDMI sync box and Hue Bridge are sold separately.
Product Description | Philips Hue Play Gradient - light strip - LED - 20 W - multicolour light - black | Product Type | Light strip | Light Source Type | LED | Light Cover Type | Diffuser | Colour | Black | Wattage | 20 W | Colour of Illumination | Multicolour light | Luminous Power | 1100 lumens | Beam Angle | 45 degree(s) | Voltage Required | AC 220 - 240 V |
General | |
Features | Double insulated, diffused light effect, Hue Sync technology, 55" - 60" TVs compatible |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 20 W |
Lifetime | 25000 hours |
Power Requirements | |
Miscellaneous | |
Product Material | Silicone |
Body Colour | Black |
Included Accessories | Power adapter, mounting brackets |
Package | Box |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 1.7 cm |
Height | 1.6 cm |
Length | 2.165 m |
Weight | 387 g |
Shipping Dimensions (WxDxH) / Weight | 29 cm x 29 cm x 14 cm / 1.34 kg |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
