Create a wash of colourful smart light with the sleek design of the Play light bar in black. This Play light bar, which includes a power supply that can connect up to three light bars, can be stood upright, laid horizontally, or placed onto the back of your TV with the included mounts.
Display Hue Play your way
The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space or media room.
Decorate with ambient smart lights
Transform the atmosphere of your home with just the touch of a button. Use over 16 million colours and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening.
Mount behind your TV
Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the colour of your choice.
Create your ambience with warm white to cool daylight
Set the right ambience for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice-cool daylight of winter. Connection with the Philips Hue bridge is required for this functionality.
Amplify your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colours from which to choose and countless lighting options, you can turn any living room into a private cinema – all you need to bring is the popcorn!
Connect 3 Hue Play light bars with 1 plug
Hue Play won't add to a jumble of wires behind your TV or hog too many outlets. You can connect three Hue Play smart light bars to the same power supply unit, leaving you more than enough room for all your other devices.
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Siri and Google Home to allow you to control your lights with your voice.
Full control from a smart device with the Hue bridge
Connect your Philips Hue lights with the bridge to unlock the endless possibilities of the system.
Product Description | Philips Hue White and Color Ambiance Play - light bar - LED - 16 million colours - white (pack of 2) | Product Type | Light bar | Light Source Type | LED | Packaged Quantity | 2 (specifications are for single item) | Dimmer | Yes | Colour | White | Colour of Illumination | 16 million colours | Luminous Power | 530 lumens | Platform | Hue | Voltage Required | AC 110 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Features | Protection class III |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Platform | Hue |
Miscellaneous | |
Product Material | Synthetics |
Body Colour | White |
Included Accessories | Power adapter |
Compliant Standards | IP20 |
Dimensions & Weight | |
Width | 4.4 cm |
Depth | 25.3 cm |
Height | 3.6 cm |
Weight | 710 g |
Shipping Dimensions (WxDxH) / Weight | 20.2 cm x 29.9 cm x 9.6 cm / 1.07 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
