Upgrade your movie room with this Philips Hue Play double pack. The lights connect to your phone and flood your walls with over 16 million shades of colour – a perfect backdrop for the biggest blockbusters. If you want to set the mood for date night, you can even adjust the brightness, or you can set a timer for them to go off after a few hours in case you accidentally doze off. And each light lasts for around 25,000 hours, so you won’t have to buy new ones anytime soon.
Product Description | Philips Hue Play - light strip kit - LED x 3 - total: 42 W - 16 million colours/tunable white - 2000-6500 K - black (pack of 2) | Product Type | Light strip kit | Light Source Type | 3 x LED | Packaged Quantity | 2 (specifications are for single item) | Total Wattage | 42 W | Dimmer | Yes | Colour | Black | Colour of Illumination | 16 million colours/tunable white | Colour Temperature | 2000-6500 K | Luminous Power | 530 lumens | Platform | Hue | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Features | Hue Sync technology |
Light Source | |
Type | 3 x LED |
Colour Rendering Index | 80 |
Lifetime | 10 years |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Required |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Miscellaneous | |
Product Material | Synthetics |
Body Colour | Black |
Included Accessories | Power supply |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 4.4 cm |
Depth | 25.3 cm |
Height | 3.6 cm |
Shipping Dimensions (WxDxH) / Weight | 20 cm x 30 cm x 10 cm / 1.69 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
