Philips Hue Single (GU10) *V2
£49.99
Delivery:
Standard: 1-3 working days
Key features
  • Paint with light
  • Sync light to music and movies
  • Create your ambiance
  • Light for your well-being
  • Wake-up naturally
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Product Description Philips Hue White and color ambiance - LED light bulb with reflector
Light Bulb Type LED light bulb with reflector
Socket Type GU10
Wattage 6.5 W
Colour of Illumination 16 million colours
Colour Temperature 2000-6500 K
Luminous Power 250 lumens
Beam Angle 160 degree(s)
Dimmable Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue Single (GU...
£49.99
