We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Philips Hue White Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - E27 - 9.5 W - soft white light - 2700 K - white | Product Type | Wireless lighting set | Light Source Type | 2 x LED light bulb | Supported Light Bulbs Qty | 50 | Dimmer | Yes | Colour | White | Shape | A60 | Socket Type | E27 | Wattage | 9.5 W | Wattage Equivalent | 75 W | Energy Efficiency Class | F | Colour of Illumination | Soft white light | Colour Temperature | 2700 K | Luminous Power | 1055 lumens | Intelligent Assistant | Alexa - indirect | Platform | Apple HomeKit | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 100 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Dimmer | Yes |
Light Source | |
Shape | A60 |
Socket Type | E27 |
Wattage | 9.5 W |
Energy Consumption per 1000h | 10 kWh |
Power Factor | 0.5 |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, Android compatible, iOS compatible |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Included |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Intelligent Assistant | Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Body Colour | White |
Included Accessories | Power adapter, network cable |
Warranty | 2 years |
Dimensions & Weight | |
Dimensions & Weight Details | Light bulb height: 110 mm x diameter: 61 mm - 73 g , Wireless bridge height: 2.6 cm x diameter: 8.8 cm |
Shipping Dimensions (WxDxH) / Weight | 17.6 cm x 14.6 cm x 14 cm / 760 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
