Marketing description is not available.
Product Description | Philips Hue White ambiance - LED spot light bulb - GU10 - 4.3 W - warm to cool white light - 2200-6500 K (pack of 3) | Light Source Type | LED spot light bulb | Packaged Quantity | 3 (specifications are for single item) | Socket Type | GU10 | Wattage | 4.3 W | Energy Efficiency Class | G | Colour of Illumination | Warm to cool white light | Colour Temperature | 2200-6500 K | Luminous Power | 350 lumens | Dimmable | Yes | Intelligent Assistant | Cortana, Google Assistant, Alexa, Apple HomeKit - indirect | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Light Source | |
Wattage | 4.3 W |
Energy Consumption per 1000h | 4.3 kWh |
Power Factor | 0.5 |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Intelligent Assistant | Cortana, Google Assistant, Alexa, Apple HomeKit |
Voice Controlled | Indirect |
Miscellaneous | |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 50 mm |
Length | 58 mm |
Weight | 153 g |
Shipping Dimensions (WxDxH) / Weight | 7.2 cm x 14.6 cm x 17.4 cm / 214 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
