Get the classic look of a vintage bulb in a smaller size. The Filament candle bulb has a coiled inner filament and E14 base, perfect for small fixtures where you want vintage style with a modern twist.
Product Description | Philips Hue White - LED filament light bulb - shape: candle - clear finish - E14 - 4.5 W - soft warm white light - 2100 K | Light Source Type | LED filament light bulb | Shape | Candle | Bulb Finish | Clear | Socket Type | E14 | Wattage | 4.5 W | Wattage Equivalent | 28 W | Energy Efficiency Class | G | Colour of Illumination | Soft warm white light | Colour Temperature | 2100 K | Luminous Power | 300 lumens | Beam Angle | 360 degree(s) | Dimmable | Yes | Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
Light Source | |
Shape | Candle |
Socket Type | E14 |
Wattage | 4.5 W |
Energy Consumption per 1000h | 5 kWh |
Power Factor | 0.6 |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, remote controlled, app-controlled, coiled filament |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Intelligent Assistant | Siri, Cortana, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 39 mm |
Length | 117 mm |
Weight | 32 g |
Shipping Dimensions (WxDxH) / Weight | 7.2 cm x 5.5 cm x 17.4 cm / 70 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
