We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Make a statement with a round LED globe bulb featuring a coiled filament design. Vintage in style but still modern, filament bulbs can do everything other smart bulbs can do, including dimming and brightening.
Product Description | Philips Hue - LED filament light bulb - shape: G125 - B22 - 7 W - soft white light - 2100 K - transparent | Light Source Type | LED filament light bulb | Colour | Transparent | Shape | G125 | Socket Type | B22 | Wattage | 7 W | Wattage Equivalent | 40 W | Energy Efficiency Class | G | Colour of Illumination | Soft white light | Colour Temperature | 2100 K | Luminous Power | 550 lumens | Dimmable | Yes | Intelligent Assistant | Cortana, Google Assistant, Alexa | Platform | Apple HomeKit | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
Light Source | |
Shape | G125 |
Socket Type | B22 |
Wattage | 7 W |
Energy Consumption per 1000h | 7 kWh |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 50000 |
Features | Instant full light, Android compatible, iOS compatible, voice control, app-controlled, retro design |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Miscellaneous | |
Body Colour | Transparent |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 125 mm |
Length | 197 mm |
Weight | 115 g |
Shipping Dimensions (WxDxH) / Weight | 140 mm x 140 mm x 240 mm / 285 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
