Philips Hue White Ambiance 3 Bulb E27 + Switch Starter Kit
FREE DELIVERY
£119.98
Delivery:
Key features
  • Smart control, home and away
  • Set timers for your convenience
  • Installation-free dimming
  • Control it your way
  • Hue dimmer switch incl
  • Type: Wireless lighting set
  • Compatible With: Alexa
Product codes
Always create the perfect ambience with this Philips Hue smart light starter kit. It includes three bulbs that you can turn on from your phone or tablet, so you can arrive to a bright, cosy home at the end of the day. As they’re white bulbs, you can be confident that they’ll always produce clear light. Each bulb has a simple screw fitting and a 25,000 hour lifespan too. It’s easy to set a timer as well, so when you’re sunning yourself on holiday, it’ll still look like you’re at home. The bulbs even work with the Apple HomeKit and Amazon Echo smart speakers, letting you control the lighting with simple voice commands, so you’ll never need to lift a finger.
The kit also includes the Philips Bridge hub, needed for the lights to work, and a wireless dimmer switch. You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
Key Features
  • Smart light bulb – control from your phone or tablet
  • White bulb - provides clear lighting for your home
  • Screw fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Works with Google Home, Amazon Alexa and Apple HomeKi
Product Description Philips Hue White ambiance Starter Kit - wireless lighting set - LED light bulb x 3
Product Type Wireless lighting set
Light Source Type 3 x LED light bulb
Supported Light Bulbs Qty 50
Total Wattage 28.5 W
Shape A60
Socket Type E27
Wattage 9.5 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Cool white/warm white light
Colour Temperature 2200-6500 K
Luminous Power 806 lumens
Intelligent Assistant Alexa - indirect
Platform Hue
Communications Technology Zigbee
Voltage Required AC 100 - 240 V
Frequency Required 50 - 60 Hz
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White Ambi...
£119.98
