Philips Hue White Ambiance E27 Twin Pack
FREE DELIVERY
£39.99
Select:
Delivery:
Product codes
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Product Description Philips Hue White ambiance - LED light bulb
Light Source Type LED light bulb
Packaged Quantity 2 (specifications are for single item)
Shape A60
Socket Type E27
Wattage 8.5 W
Wattage Equivalent 60 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm to cool white light
Colour Temperature 2200-6500 K
Luminous Power 806 lumens
Dimmable Yes
Intelligent Assistant Siri, Cortana, Google Assistant, Alexa - indirect
Platform Hue
Communications Technology Bluetooth
Voltage Required AC 220 - 240 V
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Packaging has been damaged in transit. Bulbs still intact
Ref: FFSC 042400
£24.36
product
Ref: FFSC 042400
Accessories
Packaging
Functional
Software
Manuals
£24.36
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White Ambi...
£39.99
