Philips Hue White Ambiance GU10 Twin Pack
FREE DELIVERY
£39.99
Select:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Wake up and go to sleep naturally
  • Relax, read, concentrate and energize with light recipes
  • Smart control, home and away
  • Set timers for your convenience
  • Installation free dimming
  • Control with your voice
  • Wirelessly controllable LED bulb
  • Dimmable only with Philips Hue compatible devices
  • Perfect fit
  • Type: Light bulb
  • Compatible With: Alexa, Cortana, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (1)
TP LINK KASA SMART WIFI POWER STRIP
= £64.97
Save £10.00
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Product Description Philips Hue White ambiance - LED light bulb with reflector
Light Source Type LED light bulb with reflector
Packaged Quantity 2 (specifications are for single item)
Socket Type GU10
Wattage 5 W
Wattage Equivalent 50 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Cool daylight/warm white light
Colour Temperature 2200-6500 K
Luminous Power 350 lumens
Dimmable Yes
Intelligent Assistant Cortana, Google Assistant, Alexa
Platform Apple HomeKit
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White Ambi...
£39.99
