The Philips Hue white and color ambiance contains 3 bulbs, a bridge and a switch. It can transform your lighting into an extraordinary experience with colored and white light. Sync lights to your music, TV and games for immersive effects.
Product Description | Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 3 - GU10 - 4.3 W - warm to cool white light - 2000-6500 K | Product Type | Wireless lighting set | Light Source Type | 3 x LED light bulb | Supported Light Bulbs Qty | 50 | Dimmer | Yes | Socket Type | GU10 | Wattage | 4.3 W | Wattage Equivalent | 35 W | Energy Efficiency Class | G | Colour of Illumination | Warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 350 lumens | Intelligent Assistant | Cortana, Google Assistant, Alexa | Platform | Apple HomeKit, Hue, Nest, Echo | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
General | |
Dimmer | Yes |
Features | Android compatible, iOS compatible, 16 million changeable colours, app-controlled, Hue Sync technology, voice control |
Light Source | |
Wattage | 4.3 W |
Energy Consumption per 1000h | 5 kWh |
Power Factor | 0.5 |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Instant full light |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Miscellaneous | |
Included Accessories | Power adapter, network cable, dimmer switch, Hue bridge |
Package | Box |
Compliant Standards | IP20 |
Warranty | 2 years |
Dimensions & Weight | |
Weight | 443 g |
Dimensions & Weight Details | Light bulb - width: 58 mm x depth: 58 mm x height: 50 mm , Wireless bridge - width: 8.8 cm x depth: 8.8 cm x height: 2.6 cm , Dimmer switch - width: 3.5 cm x depth: 1.1 cm x height: 9.2 cm - 37 g , Wall plate - width: 7 cm x depth: 1.4 cm x height: 11.5 cm |
Shipping Dimensions (WxDxH) / Weight | 21.9 cm x 17.6 cm x 14 cm / 857 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
