Twin Pack
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - B22 - 9 W - 16 million colours - 2200-6500 K (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Shape | A60 | Socket Type | B22 | Wattage | 9 W | Wattage Equivalent | 60 W | Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours | Colour Temperature | 2200-6500 K | Luminous Power | 806 lumens | Dimmable | Yes | Intelligent Assistant | Cortana, Google Assistant, Alexa | Platform | Apple HomeKit, Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
General | |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 9 W |
Dimmable | Yes |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Miscellaneous | |
Package | Hanging box |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 109 mm |
Weight | 72 g |
Shipping Dimensions (WxDxH) / Weight | 88 mm x 75 mm x 165 mm / 104 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
