With two B22 smart LED bulbs, you get millions of shades of white and coloured light as well as wireless dimming to set the mood instantly in your home. Use in any standard fixture with a bayonet base.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - B22 - 9 W - multicolour/warm to cool white light - 2000-6500 K (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Shape | A60 | Socket Type | B22 | Wattage | 9 W | Wattage Equivalent | 60 W | Energy Efficiency Class | F | Colour of Illumination | Multicolour/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 1100 lumens | Dimmable | Yes | Intelligent Assistant | Cortana, Google Assistant, Alexa - indirect | Platform | Apple HomeKit, Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
General | |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 9 W |
Energy Consumption per 1000h | 9 kWh |
Power Factor | 0.8 |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 25000 hours |
Switch Cycles | 50000 |
Features | ZigBee technology, app-controlled, 16 million changeable colours, controlled via Bluetooth |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Compatible Application | Philips Hue App |
Intelligent Assistant | Cortana, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Package | Box |
Compliant Standards | WEEE |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 109 mm |
Weight | 72 g |
Shipping Dimensions (WxDxH) / Weight | 14.6 cm x 7.2 cm x 17.4 cm / 270 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
