Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Product Description | Philips Hue White and Color Ambiance - LED light bulb - shape: B39 - E14 - 6.5 W - 16 million colours - 2200-6500 K (pack of 2) | Light Source Type | LED light bulb | Packaged Quantity | 2 (specifications are for single item) | Shape | B39 | Socket Type | E14 | Wattage | 6.5 W | Light Bulb Energy Efficiency Class | A+ | Colour of Illumination | 16 million colours | Colour Temperature | 2200-6500 K | Dimmable | Yes | Voltage Required | AC 220 - 240 V |
General | |
Light Source | |
Shape | B39 |
Socket Type | E14 |
Wattage | 6.5 W |
Energy Consumption per 1000h | 6.5 kWh |
Dimmable | Yes |
Lifetime | 25000 hours |
Features | Instant full light, Android compatible, iOS compatible, remote controlled |
Power Requirements | |
Miscellaneous | |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 39 mm |
Length | 117 mm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
