Philips Hue White GU10 Bulb
£14.98
Delivery:
Key features
  • Smart control, home and away
  • Set timers for your convenience
  • Installation-free dimming
  • Control it your way
  • Wirelessly controllable LED bulb
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest
Product codes
Add a Philips Hue white bulb to your system and enhance your home with warm white lighting that you can dim and control remotely. Automate your lights to make it seem like you're home when you're not or set timers.
Product Description Philips Hue White - LED light bulb
Light Bulb Type LED light bulb
Socket Type GU10
Wattage 5.5 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 300 lumens
Beam Angle 46 degree(s)
Dimmable Yes
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White GU10...
£14.98
