Bring vintage style to your standard light bulbs with this dimmable LED bulb featuring a coiled filament design. The smart bulb can be used with Bluetooth or paired with a Hue Bridge for ultimate control.
Product Description | Philips Hue White - LED filament light bulb - shape: A60 - B22 - 7 W - warm white light - 2100 K - transparent | Light Source Type | LED filament light bulb | Colour | Transparent | Shape | A60 | Socket Type | B22 | Wattage | 7 W | Wattage Equivalent | 40 W | Energy Efficiency Class | G | Colour of Illumination | Warm white light | Colour Temperature | 2100 K | Luminous Power | 550 lumens | Dimmable | Yes | Intelligent Assistant | Cortana, Google Assistant, Alexa | Platform | Hue | Communications Technology | Bluetooth, Zigbee | Voltage Required | AC 220 - 240 V |
Light Source | |
Shape | A60 |
Socket Type | B22 |
Wattage | 7 W |
Energy Consumption per 1000h | 7 kWh |
Colour Rendering Index | 80 |
Dimmable | Yes |
Lifetime | 15000 hours |
Switch Cycles | 50000 |
Features | Upgradable firmware, instant full light, Android compatible, iOS compatible, twisted filament |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Miscellaneous | |
Body Colour | Transparent |
Warranty | 2 years |
Dimensions & Weight | |
Diameter | 60 mm |
Length | 114 mm |
Weight | 46 g |
Shipping Dimensions (WxDxH) / Weight | 8.8 cm x 7.5 cm x 17 cm / 80 g |
Environmental Parameters | |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
