Philips Hue White Single (E27) *V2
£13.75
Delivery:
Standard: 1-3 working days
Key features
  • Control your lights from anywhere
  • Set light schedules for easy home automation
  • Guaranteed smooth wireless dimming
  • Connect up to 50 Philips Hue lights
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
  • Stock Status: In Stock
Product codes
Philips hue combines brilliant LED light with intuitive technology. It will surely change the way you use light. Forever. Experiment with shades of white, from invigorating blue/white to cozy yellow/white. Or play with all the colors in the spectrum. Hue can wake you up. Help protect your home. Relive your favorite memories. Improve your mood. Even keep you informed about the weather. Not just stunning, hue is smart too. And it's tailored for you.
Product Description Philips Hue White - LED light bulb
Light Bulb Type LED light bulb
Colour White
Shape A60
Socket Type E27
Wattage 9.5 W
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 800 lumens
Beam Angle 180 degree(s)
Dimmable Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White Sing...
£13.75
