Philips Hue White Wireless Lighting Starter Kit UK (E27)
£59.98
Delivery:
Key features
  • Set lights to turn on and off when you're away from home
  • Control from your iOS and Android smart devices
  • Perfect digital dimming
  • Use the timer to set alarms and change your lights over time
  • Customize your connected lighting
  • Enjoy light effects synced to your moment
  • Always up to date
  • Connect up to 50 bulbs and lamps
Product codes
Turn on your peace of mind with Philips Hue. Get started with the Philips Hue white starter kit and experience peace of mind by controlling your lights wherever you are. It's all about simplifying your life and giving you peace of mind in smart way. This Philips Hue bridge is compatible with Apple HomeKit technology. Ask Siri to turn on or dim your lights or recall presets without touching a single button.
  • App needed for use: philips hue.
  • Operates over mobile internet.
  • Operates over wi-fi.
  • Requires wireless router for use.
  • Controls lighting.
  • Detects occupancy.
  • Sets schedules for devices.
  • Components include 2 x 9.5w e27 edison screw philips hue white bulbs, 1 x philips hue bridge, 1 x lan cable, 1 x power adapter.
  • (not included).
Philips Hue Starter Kit - wireless lighting set - LED light bulb x 2
Wireless lighting set
Light Bulb Type
2 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
19 W
Dimmer
Shape
A19
Socket Type
E27
Wattage
9.5 W
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
180 degree(s)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Hue White Wire...
£59.98
