We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Clear vision to get more done
Get your best work done with this Philips monitor. IPS screen with crisp FHD gives you the clarity to see your work. Loaded with features to improve productivity and sustainability. Eye comfort features with TUV certified to reduce eye fatigue.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
SmartImage pre-sets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
EasyRead mode for a paper-like reading experience
Product Description | Philips B Line 242B1 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Power Consumption (On mode) | 16.6 W | Features | USB 3.2 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 107% sRGB (CIE 1931), 91% NTSC (CIE 1976) | Input Connectors | HDMI, DVI-D, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black texture | Dimensions (WxDxH) - with stand | 54 cm x 20.5 cm x 50.1 cm | Weight | 4.57 kg | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, CCC, TUV Ergo, DDC/CI, RoHS, Lead-Free, CECP, CEL, EPA, CU-EAC, DisplayPort 1.2, BFR-free, PVC-free, Mercury-free | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 3.2 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Multilingual |
Features | Sync on Green, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, LightSensor, EasyRead, sRGB Mode |
Dimensions (WxDxH) | 54 cm x 20.5 cm x 50.1 cm - with stand |
Weight | 4.57 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) , DisplayPort , HDMI , USB upstream , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 360 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.6 kWh/1000h |
Power Consumption (Typical) | 14.5 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand (highest position) - width: 54 cm - depth: 20.5 cm - height: 50.1 cm - weight: 4.57 kg , Without stand - width: 54 cm - depth: 5.1 cm - height: 32.3 cm - weight: 2.99 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 60 cm |
Shipping Depth | 19.8 cm |
Shipping Height | 46.5 cm |
Shipping Weight | 6.74 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
