Philips Momentum 436M6VBPAB 43" 2840x2160 4ms HDMI Displ...
Philips Momentum 436M6VBPAB 43" 2840x2160 4ms HDMI DisplayPort USB-C LED Monitor
£505.24
Delivery:
Key features
  • UltraClear 4K UHD (3840x2160) resolution for precision
  • MultiView enables active dual connect and view at same time
  • High Dynamic Range (HDR) for more lifelike colorful visuals
  • Quantum Dot Tech for see-it-to-believe-it color
  • Ambiglow intensifies entertainment with halo of light
  • Enhanced audio with DTS Sound
  • Low input lag reduces time delay between devices to monitor
  • Effortlessly smooth gameplay with Adaptive Sync technology
  • All your connections through one USB-C cable
Product codes
Experience a new level of entertainment immersion with the new Momentum 4K HDR display with Ambiglow lighting. An expansive 4K UHD display with DisplayHDR 1000 delivers ultra-crisp and vibrant image quality that will get you in the moment.
Product Description Philips Momentum 436M6VBPAB - LED monitor - 4K - 43"
Device Type LED-backlit LCD monitor - 43"
Energy Class Class C
Energy Consumption per Year 201 kWh
Power Consumption (On mode) 138 W
Features USB 3.0 hub
Panel Type MVA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Pixel Pitch 0.245 mm
Brightness 1000 cd/m²
Contrast Ratio 4000:1 / 50000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments Tilt
Screen Coating Anti-glare, 3H Hard Coating, low haze
Colour Black gloss textured
Dimensions (WxDxH) - with stand 97.6 cm x 26.4 cm x 66.1 cm
Weight 14.71 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV, VCCI, BSMI, ICES-003, SASO, SEMKO, CB, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, KC, KUCAS, EAC, cETLus, China RoHS, RCM, Ukraine
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips Momentum 436M6...
£505.24
