The Philips USB-C docking display for a comprehensive solution. View UltraClear 4K UHD and recharge a laptop, all at the same time with a single USB-C cable. Integrated KVM switch and multiple connections for performance and convenience.
USB-C enables laptop power charging directly from a monitor
This Philips display features a built-in USB type-C docking station with power delivery. With intelligent and flexible power management, you can power charge your compatible* laptop directly. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. You can watch high-resolution video and transfer data at super-speed, while powering up and re-charging your notebook at the same time.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
DisplayHDR 400 for more lifelike and outstanding visuals
VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike, other "HDR-compatible" screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and peak brightness up to 400 nits, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
Ultra Wide-Color wider range of colours for a vivid picture
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
MultiView 4K for 4 systems on one screen
Philips MultiView feature on this expansive 4K UHD display enables you to have up to four systems each shown in Full HD on one screen. You can use Picture-by-Picture (PbP) to monitor four systems on one screen for control rooms or security. Or for multiple devices like two notebooks side-by-side simultaneously, making collaboration more productive. Or Picture-in-Picture mode (PiP) watching a live football feed from your set-top box, while working on your PC.
Built-in KVM switch to easily switch between sources
With the MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse setup. A convenient button allows you to quickly switch between sources. Handy with setups that require dual PC computing power or sharing one large monitor to show two different PCs.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Tilt, swivel and height-adjust for an ideal viewing position
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
VA display delivers awesome images with wide viewing angles
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
Built-in RJ-45 Ethernet gives data security
EasyRead mode for a paper-like reading experience
Product Description | Philips P-line 439P1 - LED monitor - 4K - 43" - HDR | Device Type | LED-backlit LCD monitor - 43" | Energy Class | Class G | Power Consumption (On mode) | 60 W | Features | KVM Switch, USB 3.2/USB-C hub, USB PD 15 Watt | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI 1.4: 30 Hz, HDMI 2.0: 60 Hz, USB-C: 60 Hz) | Pixel Pitch | 0.2451 mm | Brightness | 400 cd/m² | Contrast Ratio | 4000:1 / 50000000:1 (dynamic) | HDR Capable | DisplayHDR 400 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 105% NTSC (CIE 1976), 126% sRGB (CIE 1931), 90% Adobe RGB (CIE 1976) | Input Connectors | 3xHDMI, DisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating, Haze 25% | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black texture | Dimensions (WxDxH) - with stand | 97.8 cm x 28.1 cm x 67.7 cm | Weight | 12.4 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, CU-EAC, BFR-free, PVC-free, Mercury-free, EAEU RoHS | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 43" |
Viewable Size | 42.51" |
Built-in Devices | KVM Switch, USB 3.2/USB-C hub |
USB Power Delivery | 15 Watt |
Panel Type | VA |
Pixel Per Inch | 103.64 |
HDR Certification | DisplayHDR 400 |
Vertical Refresh Rate | 48 - 60 Hz |
Horizontal Refresh Rate | 30 - 140 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features | Picture by picture, Eco-Mode, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, SmartUniformity, Adaptive-Sync technology, EasyRead, Ultra Wide-Color Technology, sRGB Mode, Picture-in-Picture, Delta E<2 calibration, HBR3 for USB-C |
Dimensions (WxDxH) | 97.8 cm x 28.1 cm x 67.7 cm - with stand |
Weight | 12.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | DisplayPort 1.4 (HDCP 2.2) , 2 x HDMI (HDCP 2.2) , HDMI (HDCP 1.4) , USB-C upstream , USB upstream (Type B) , 2 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , USB-C downstream (power up to 15W) , Headphones , Network (RJ-45) , RS-232 |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 90 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 200 x 200 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), wake on LAN, DisplayPort Alt Mode |
Cables Included | HDMI cable , DisplayPort cable , USB-A to USB-B cable , USB-C to USB-C / USB-A cable |
MTBF | 70,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 60 kWh/1000h |
Power Consumption HDR (On mode) | 91 kWh/1000h |
Power Consumption (Typical) | 46 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0 Watt |
On / Off Switch | Yes |
Software / System Requirements | |
Included Software | Philips SmartControl |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 97.8 cm - depth: 28.1 cm - height: 67.7 cm - weight: 12.4 kg , Without stand - width: 97.8 cm - depth: 7.8 cm - height: 57.3 cm - weight: 5.6 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 115 cm |
Shipping Depth | 28.4 cm |
Shipping Height | 70.4 cm |
Shipping Weight | 23.3 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
