Philips S-line LED monitor 22" 1680 x 1050 DVD-D VGA
£149.98
Delivery:
Key features
  • S Line
  • 22" (55.9 cm)
  • 1680 x 1050 (WSXGA)
  • Diagonal Size: 22in
  • Max Resolution: 1680 x 1050
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The Philips ergonomic LED display using 25% recycled materials and PVC-BFR free housing is ideal for eco-friendly productivity.
Product Description Philips S-line 220S4LYCB - LED monitor - 22"
Device Type LED-backlit LCD monitor - 22"
Aspect Ratio 16:10
Native Resolution 1680 x 1050 at 60 Hz
Pixel Pitch 0.282 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Textured black
Dimensions (WxDxH) - with stand 50.4 cm x 22.7 cm x 50.9 cm
Weight 5.2 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, UL, TUV, TUV GS, BSMI, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, CECP, CU-EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips S-line LED mon...
£149.98
