General |
Display Type |
LED-backlit LCD monitor / TFT active matrix |
Energy Class |
Class A |
Energy Consumption per Year |
31 kWh |
Power Consumption (On mode) |
21 W |
Diagonal Size |
24" |
Viewable Size |
23.8" |
Panel Type |
IPS |
Aspect Ratio |
16:9 |
Native Resolution |
Full HD (1080p) 1920 x 1080 at 60 Hz |
Pixel Pitch |
0.275 mm |
Pixel Per Inch |
93 |
Brightness |
250 cd/m² |
Contrast Ratio |
1000:1 / 10000000:1 (dynamic) |
Colour Support |
16.7 million colours |
Response Time |
5 ms (grey-to-grey) |
Vertical Refresh Rate |
56 - 76 Hz |
Horizontal Refresh Rate |
30 - 83 kHz |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Backlight Technology |
WLED |
OSD Languages |
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean |
Features |
Sync on Green, sRGB colour management, SmartContrast, SmartImage, edge-to-edge glass, SmartConnect, Low Blue Light Mode, Flicker Free technology, Ultra Narrow Border, Mercury free, Wide Viewing Angle, EasyRead |
Colour |
Textured black |
Dimensions (WxDxH) |
54 cm x 20.9 cm x 41.5 cm - with stand |
Weight |
3.5 kg |
Audio |
Type |
Speakers - stereo |
Output Power / Channel |
2 Watt |
Connectivity |
Interfaces |
VGA , HDMI (HDCP) , DisplayPort |
Mechanical |
Display Position Adjustments |
Tilt |
Tilt Angle |
-5/+20 |
VESA Mounting Interface |
100 x 100 mm |
Miscellaneous |
Features |
Security lock slot (cable lock sold separately) |
Cables Included |
1 x VGA cable , 1 x audio cable |
MTBF |
50,000 hour(s) |
Compliant Standards |
Plug and Play, FCC Class B certified, TUV, VCCI, ICES-003, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, KCC, WEEE, CECP, cETLus, RCM, CU |
Power |
Voltage Required |
AC 120/230 V (50/60 Hz) |
Power Consumption Operational |
13.82 Watt |
Power Consumption Stand by |
0.5 Watt |
Power Consumption (Off Mode) |
0.5 Watt |
Software / System Requirements |
OS Required |
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 |
Dimensions & Weight |
Dimensions & Weight Details |
With stand - width: 54 cm - depth: 20.9 cm - height: 41.5 cm - weight: 3.5 kg , Without stand - width: 54 cm - depth: 4.5 cm - height: 32.5 cm - weight: 3.08 kg |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
