Philips X-Line 34" HDMI DisplayPort Monitor
£607.70
Delivery:
Standard: 1-3 working days
Key features
  • X Line
  • 34" (86.36 cm)
  • WQHD (3440 x 1440)
  • Diagonal Size: 34in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
This Philips UltraWide 34" display will amaze you with its Crystal clear 3440 x 1440 images and brilliant colours. Its fascinating UltraWide display with height adjustability gives you a panoramic view of the world.
Product Description Philips Brilliance X-line 349X7FJEW - LED monitor - curved - 34"
Device Type LED-backlit LCD monitor - 34"
Energy Class Class C
Energy Consumption per Year 114 kWh
Power Consumption (On mode) 78 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Aspect Ratio 21:9
Native Resolution 3440 x 1440 at 60 Hz
Pixel Pitch 0.232 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1 / 50000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, tilt
Colour White, glossy, silver chrome
Dimensions (WxDxH) - with stand 81 cm x 29.2 cm x 44.4 cm
Weight 8.21 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, RCM, CU-EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Philips X-Line 34" HDM...
£607.70
