Music makes any moment more personal. Get lost in rich, lifelike audio and make every moment your own. With hours of continuous wireless use, you’re going to need a longer playlist.
Product Description | Plantronics Backbeat Pro - headphones with mic | Product Type | Headphones - Bluetooth - wireless - NFC | Recommended Use | Portable electronics | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 4.0 EDR | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz | Active Noise Canceling | Yes | Microphone | Built-in | Controls | Volume, answer/end, microphone on/mute, play/pause |
General | |
Product Type | Headphones - Bluetooth - NFC |
Weight | 340 g |
Max Operating Distance | 100 m |
Headphones | |
Headphones Form Factor | Circumaural |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Diaphragm | 40 mm |
Remote Control | |
Wireless Link | |
Transmission Range | 100 m |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm 4-pole) |
Cable | |
Detachable Cable | Yes |
Miscellaneous | |
Cables Included | USB charge cable , Microphone cable - detachable - L shaped |
Included Accessories | Carrying pouch |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Run Time (Up To) | 24 hour(s) |
Standby Time | 504 hours |
Recharge Time | 3 hours |
