Plantronics Blackwire 5210 C5210 USB-A WW
£80.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • All-day comfort and universal connectivity
  • Outstanding audio quality for better productivity
  • A headset that works the way you do
  • Recommended Use: Computer
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
The Blackwire 5200 Series fits your busy workday. Easy to use, USB-C and 3.5 mm connectivity lets you work on a variety of devices. And it's so comfortable, you'll be able to wear it all day. The Blackwire 5200 Series-connect, work, seamlessly.
Product Description Poly Blackwire 5210 - headset
Product Type Headset - wired - USB, 3.5 mm jack
Recommended Use Computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Mono
Audio Specifications Frequency Response 20 - 20000 Hz
Microphone Boom
Controls Mute, volume, answer/end
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Plantronics Blackwire...
£80.74
