Plantronics EncorePro HW510D Noise Cancelling Mono Headset
£106.84
14 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Enhanced interactions, better control
  • Great performance
  • Recommended Use: Computer, Phone, Phone
  • Connectivity: Wired
  • Earcover : Monaural
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £110.33
Save £1.50
The EncorePro 500 Digital Series with DA90 USB audio processor and Plantronics Manager Pro is the first of its kind: a fully integrated audio and asset management solution.
Product Description Poly EncorePro HW510D - headset
Product Type Headset - wired
Recommended Use Phone, computer
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Mono
Microphone Boom
Microphone Operation Mode Mono
Environmental Standards TCO Certified Headsets 3
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: CVV9 042566
£41.18
product
Ref: CVV9 042566
Accessories
Packaging
Functional
Software
Manuals
£41.18
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Plantronics EncorePro...
£106.84
