Plantronics RIG 500 HX Sand Camo Headset
Key features
  • Stereo headset for Xbox One
  • Focus wins
  • Configure to win
  • Performance audio
Product codes
Designed for Xbox One, the RIG 500HX headset delivers performance audio you can count on with durable, lightweight comfort for competitive challenges.
FOCUS WINS
The durable yet lightweight frame lets you configure components for endurance or focus. The included isolating earcups immerse you in the game, blocking out distracting background noise.
CONFIGURE TO WIN
RIG 500 is designed to let you change out components to match your needs. Opt for immersive, isolating cups to game in peace or choose the open, vented cups to keep your cool during long sessions. The flexible headset frame can be swapped out for translucent or camo colour options.
PERFORMANCE AUDIO
Audio fidelity that gives you an edge. Dynamic, 40mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-cancelling boom mic flips up to mute, making it perfect for solo campaigns.
Product Description Plantronics RIG 500HX CAMO - headset
Product Type Headset - wired
Recommended Use Game console
Colour Sand camo
Headphones Form Factor Full size
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 111 dB
Impedance 32 Ohm
Max Input Power 40 mW
Noise Isolating Noise isolating
Microphone Boom
Controls Microphone on/mute
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Plantronics RIG 500 HX...
