Plantronics Voyager 5200 (consumer)
£133.58
Delivery:
Key features
  • Voice control
  • Reliable clarity
  • Adaptive microphones
  • Smart sensors
  • Sweatproof nano-coating
  • Windsmart technology
  • Software-enabled functionality
  • Recommended Use: Portable electronics
  • Connectivity: Wireless
Product codes
Raise the power of your voice. A dedicated voice control button easily activates Siri, Google Now, or Cortana. Whispered alerts update you on talk time, and even announce the names of incoming callers so you can simply say "Answer" or "Ignore" to calls without lifting a finger.
From bustling city streets to the corner café, some of life's most important calls happen in the most unexpected places. The noise canceling and six layers of WindSmart technology eliminate disruptive background noise like wind and chatter so your voice sounds clear, indoors and out.
Voice Control
Reliable Clarity
Adaptive Microphones
Work together to reduce disruptive background noise.
Smart Sensors
Smart sensor technology uses contextual intelligence to keep up with you.
Sweatproof Nano-Coating
Protected against light rain, humidity, and sweat.
Windsmart Technology
Detects wind direction and responds accordingly.
Software-Enabled Functionality
Use Plantronics Hub mobile app to locate your lost headset, change languages, wirelessly update firmware, or personalize settings and alerts. Use Plantronics Hub desktop software to view headset battery meter, change languages, update firmware, enable softphone call control, or personalize settings and alerts.
Product Description Poly Voyager 5200 - headset
Product Type Headset - Bluetooth - wireless
Compatibility iPhone, iPad, iPod, Android phone
Recommended Use Portable electronics
Additional Functions DSP
Localisation Europe
Headphones Form Factor Ear-bud - over-the-ear mount
Connectivity Technology Wireless
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 4.1
Sound Output Mode Mono
Microphone Boom
Microphone Active Noise Cancelling Yes
Controls Volume, mute button
TCO Certified TCO Certified Headsets 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Plantronics Voyager 52...
£133.58
