Plantronics Voyager 8200UC B8200 Wireless Stereo Headset - Black
£248.30
Delivery:
Standard: 1-3 working days
Key features
  • Concentrate in comfort
  • Immerse yourself in rich audio
  • Boomless design
  • Dual-mode ANC
  • Dynamic mute alert
  • Smart sensors
  • Recommended Use: Computer, Portable electronics
  • Connectivity: Wireless
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £251.79
Save £1.50
With its contemporary, boomless design and active noise canceling, Voyager 8200 UC blocks out background noise so you can concentrate on your work or your call in comfort and style. Soft ear cushions, 24 hours of listening time and a 3.5 mm audio cable allow you to take calls or play music whether you're in the office, on a flight or on the go. Roam with ease at a range of up to 30 m/98 ft with a Class 1 Bluetooth device.
Hear music and conversations with complete clarity. All tones, from high to low and everything in between, sound full and natural. Need to tune out distractions? The hi-fi stereo sound and dual-mode active noise canceling cut background noise while the boomless dual-paired microphones keep the focus on your voice.
Stay connected
Need to connect to your computer and mobile phone? No problem. By staying connected to two devices at once, you'll never miss a call. Play music or answer your phone simply by putting on the headset, and pause your media player or mute a call by taking it off. A dedicated button gives you quick access to mute, while voice prompts alert you if you're on mute when you start talking.
Customize your experience
Choose the settings that make your life easier with the Plantronics Hub app for iPhone and Android. Select language preference, feature settings, call, and mute notifications. Keep your device updated with Plantronics Hub over-the-air firmware updates.
Seamless IT management
Plantronics Manager Pro, when used with Plantronics-supported devices such as Voyager 8200 UC, is software-as-a-service that allows IT to manage headset inventory, monitor usage, and maintain devices -- all from a web browser.
  • Boomless design
  • Dual-mode ANC
  • Smart sensory technology
  • Intuitive controls
  • Extended range
  • Plantronics signature audio
  • Multi-device connectivity
  • BT600 USB Bluetooth adaptor
  • Extended battery life
  • OpenMic
Product Description Poly - Plantronics Voyager 8200 UC - headphones with mic
Product Type Headphones - Bluetooth - wireless - NFC - 3.5 mm jack
Recommended Use Portable electronics, computer
Additional Functions DSP
Localisation Worldwide
Colour Black
Headphones Form Factor Full size
Connectivity Technology Wireless
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 4.1
Sound Output Mode Stereo
Active Noise Canceling Yes
Microphone Active Noise Cancelling Yes
Microphones Included 4
Controls Mute, volume control, on/off, answer/end, next/previous track, reject call, redial
Intelligent Assistant Siri, Cortana, Google Now
Software Certification Certified for Microsoft Teams
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Plantronics Voyager 82...
£248.30
