Poly P10H/A ADAPTER
Poly P10H/A ADAPTER
£90.85
Delivery:
Product codes
PBX and ACD operators can enjoy the comfort and convenience of Plantronics technology with the P10 plug prong adapter with built-in high-gain amplifier. The P10 adapter works with your choice of Plantronics headsets so you can choose the style that best meets your application needs. Just plug the P10 adapter into your operator console, PBX, or ACD, then plug in your headset. The P10 adapter delivers Plantronics famous sound quality and ease of use. Its volume and automatic gain controls let you adjust incoming calls to a listening level that's comfortable for you.
The P10H adapter comes with built-in high-gain amplifier.
Product Description Poly - Plantronics P10 Series P10H - adapter for headset
Product Type Adapter
Intended For Headset
Localisation English
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Poly P10H/A ADAPTER
£90.85
