We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
BackBeat Pro 2 wireless headphones shape the sounds of your day with on-demand active noise canceling, wireless freedom, and immersive audio.
Product Description | Poly - Plantronics Backbeat Pro 2 - headphones with mic | Product Type | Headphones - Bluetooth - wireless | Recommended Use | Portable electronics | Colour | Black | Image Colour Disclaimer | The displayed product image may be a different colour | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 4.0 EDR | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 93 dB | Impedance | 32 Ohm | Active Noise Canceling | Yes | Controls | Volume, answer/end, play/pause, next/previous track |
General | |
Weight | 289 g |
Colour | Black |
Max Operating Distance | 100 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 93 dB |
Diaphragm | 40 mm |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Wireless Link | |
Transmission Range | 100 m |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm 4-pole) |
Miscellaneous | |
Included Accessories | Travel pouch |
Cable Details | USB charge cable , Headphones cable |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Run Time (Up To) | 24 hour(s) |
Recharge Time | 3 hours |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
