The great appeal of the Blackwire 3300 is apparent at first sight: It has a sleek, modern design. Workers want to wear it-so your investment pays off. Not only that, it sounds as good as it looks, with high-quality audio you've come to expect from Poly.
Product Description | Poly Blackwire 3320 - headset | Product Type | Headset - wired - USB | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 94 dB | Impedance | 32 Ohm | Microphone | Boom | Microphone Noise Cancelling | Yes | Controls | Mute, volume, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Series | 3300 Series |
Weight | 130 g |
Protection | Hearing protection |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 94 dB |
Diaphragm | 32 mm |
In-Cord Volume Control | Yes |
Adjustable Headband | Yes |
Features | SoundGuard Technology |
Microphone | |
Type | Boom |
Sensitivity | -38 dB |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Miscellaneous | |
Cable Details | Headset cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
