Poly Plantronics EncorePro HW520 Noise Cancelling Duo Corded...
Poly Plantronics EncorePro HW520 Noise Cancelling Duo Corded Headset
£96.56
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Next-generation custom microphone reduces background noise and interference, ensuring fewer missed words and a better caller experience
  • Tactile and visual guidance mean the user can feel and hear ratchet clicks when the boom is moved into the proper range for optimum mic positioning
  • Tuned wideband audio delivers richer, clearer conversations while SoundGuard technology protects user from noise spikes and listening fatigue
  • Metals employed structurally, not cosmetically, at key joints
  • UniKeySellingPoints flexible boom and laser welding ensure maximum robustness
  • Quick Disconnect (QD) feature provides walkaway convenience and compatibility with all Plantronics USB and deskphone audio processors and direct connect cables
  • Recommended Use: Phone, Phone
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £100.05
Save £1.50
Feel the difference with the EncorePro. The over-the-head headset incorporates a range of leading design features to enhance the performance of your customer service representatives.
The sophisticated new design offers visual and tactile boom positioning feedback, ensuring the microphone is placed correctly for the clearest conversations. Lighter weight and softer, more luxurious ear cushions create a level in comfort for staff who need to be performing at their peak all day, every day. And with laser welding and aircraft-grade aluminum, this is the most durable EncorePro yet.
EncorePro headsets require a Plantronics audio processor or direct connect cable to connect to phone, or USB audio processor to connect to computer.
Product Description Poly EncorePro HW520 - headset
Product Type Headset - wired
Recommended Use Phone
Localisation Middle East, Africa, Europe
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 100 - 6800 Hz
Impedance 320 Ohm
Microphone Boom
Microphone Operation Mode Mono
Environmental Standards TCO Certified Headsets 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Poly Plantronics Encor...
£96.56
