Enjoy simply better conversations with the Savi 8200 Series. Effortlessly manage PC, mobile and desk phone calls, with enterprise-grade DECT audio.
Product Description | Poly Savi 8200 Series W8210/A - headset | Product Type | Headset - DECT / Bluetooth - wireless | Recommended Use | Phone, computer | Localisation | EMEA | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | DECT / Bluetooth | Bluetooth Version | Bluetooth 4.2 | Sound Output Mode | Mono | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 118 dB | Impedance | 32 Ohm | Active Noise Canceling | Yes | Microphone | Boom | Controls | Mute, volume, on/off, answer/end |
General | |
Weight | 115 g |
Max Operating Distance | 180 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 118 dB |
Diaphragm | 32 mm |
Microphone | |
Type | Boom |
Frequency Response | 100 - 6800 Hz |
Max Sound Pressure | 112 dB |
Remote Control | |
Miscellaneous | |
Included Accessories | Base station, charging cradle, power supply unit |
Cable Details | USB cable , Phone cable , USB-C cable |
Power | |
Battery | Headset battery rechargeable - lithium polymer |
Capacity | 490 mAh |
Run Time (Up To) | 13 hour(s) |
Standby Time | 50 hours |
Recharge Time | 3 hour(s) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
