Poly Y Cable - Training Cord with Microphone Mute & Quick...
Poly Y Cable - Training Cord with Microphone Mute & Quick Disconnect
£25.53
4 on order, no confirmed delivery date
Delivery:
  • Stock Status:
    Used stock also available below
Product codes
For Plantronics A22, E10, M12, P10, S20 CA40, P10, P10H
Ideal for listening in to calls for training and coaching purposes, this Adapter Trainer Cord with Microphone Mute Switch and Quick Disconnect Clamp will allow for supervised calls for maximum effectiveness. (4 pin Quick Disconnect/QD only)
Plantronics' mission is to enhance personal communication. By allowing you to be more productive, safe, and comfortable you'll notice a marked improvment in the clarity of your daily communications.
Product Description Poly Y Adapter Trainer - headset splitter
Cable Headset splitter
Connector Quick Disconnect
Connector (Second End) 2 x Quick Disconnect
Designed For Avaya M12LU/CM, M12LUCM; Poly A22, E10, M12, M22, MX10, P10, S20; Headset Switcher MX10; P10 Series P10H
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: 4RQG 040294
£3.79
product
Ref: 4RQG 040295
£3.79
product
Ref: 4RQG 040296
£3.79
product
Ref: 4RQG 040294
Accessories
Packaging
Functional
Software
Manuals
£3.79
product
Ref: 4RQG 040295
Accessories
Packaging
Functional
Software
Manuals
£3.79
product
Ref: 4RQG 040296
Accessories
Packaging
Functional
Software
Manuals
£3.79
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£25.53
