Praktica Luxmedia WP240 Orange Camera Kit inc 16GB MicroSD Ca...
Praktica Luxmedia WP240 Orange Camera Kit inc 16GB MicroSD Card and Case
£79.99
34 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 20MP CCD Sensor
  • 4x Optical Zoom Lens
  • Waterproof 10m IPX8/ Dust proof IP5X
  • 28 fun and creative modes
  • 64MB Internal Memory
  • Micro SD Card slot
  • Video recording: 720p30/VGAp30
  • 2.7 inch LCD Screen
  • Type: Compact
  • Resolution: 20Megapixel
  • Optical Zoom: 4
  • Colour: Orange
  • Stock Status: In Stock
Product codes
Small, waterproof and easy to use, the PRAKTICA WP240 is the ideal camera for families on the go. Built with 20 Megapixels and 4x Optical Zoom, the WP240 boasts a slim colorful structure which is easy to operate for all ages.
Product Description PRAKTICA Luxmedia WP240 - digital camera
Product Type Digital camera - 720p - compact
Memory Card Slot microSD card
Sensor Resolution 20.0 Megapixel
Max Video Resolution 1280 x 720
Lens System Zoom lens - 4x zoom - 4.6 - 18.4 mm - f/3.2-5.8
Focus Adjustment Automatic, manual
Digital Zoom 8x
Image Stabiliser Electronic
Camera Flash Built-in flash
Display LCD display - 2.7"
Supported Battery 1 x Li-ion rechargeable battery - 700 mAh (included)
Interface Composite video/audio, USB 2.0
Colour Orange
Dimensions (WxDxH) 10.8 cm x 5.05 cm x 6.62 cm
Weight 162 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Praktica Luxmedia WP24...
£79.99
