General |
Product Type |
Digital camera - 720p - compact |
Enclosure Colour |
Black |
Sensor Resolution |
20.0 Megapixel |
Optical Sensor Type |
CCD |
Total Pixels |
20,480,000 pixels |
Effective Sensor Resolution |
20,160,000 pixels |
Optical Sensor Size |
1/2.3" |
Frame Rate (Max Resolution) |
30 fps |
ISO (Max) |
6400 |
Optical Zoom |
12x |
Image Stabiliser |
Optical |
Built-in Optical Image Stabiliser |
Yes |
Print Standard |
DPOF support, Exif Print support |
Auto Focus |
TTL contrast detection |
Digital Video Format |
AVI, MJPEG |
Image Recording Format |
JPEG |
Max Video Resolution |
1280 x 720 |
Interface |
USB 2.0, Wireless LAN |
Computer Connectivity |
Mac, Windows |
Connectivity Features |
Remote control via mobile devices |
Exposure & White Balance |
Light Sensitivity |
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto |
Exposure Metering |
Multi-segment, centre-weighted, spot |
Exposure Modes |
Programme, automatic |
White Balance |
Custom, automatic, presets |
White Balance Presets |
Cloudy, tungsten light, daylight, fluorescent light (cool white), fluorescent light (warm white) |
Max Shutter Speed |
1/2000 sec |
Min Shutter Speed |
4 sec |
Exposure Compensation |
±2 EV range, in 1/3 EV steps |
Lens System |
Type |
Zoom lens - 12x zoom - 4.3 - 51.6 mm - f/3.1-6.3 |
Focal Length Equivalent to 35mm Camera |
24 - 288mm |
Focus Adjustment |
Automatic |
Min Focus Distance |
40 cm |
Macro Focus Range |
3cm |
Zoom Adjustment |
Motorised drive |
Features |
Built-in lens shield |
Camera Flash |
Camera Flash |
Built-in flash |
Flash Modes |
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction |
Red-Eye Reduction |
Yes |
Additional Features |
Self-Timer Delay |
10 sec, 2sec |
Multi-picture burst, AE lock, AF lock, Intelligent Scene Selector, D-Lighting technology, Panorama Capture, Time-Lapse recording, GPS via mobile |
Tripod Mount |
Connection Point |
Yes |
Display |
Type |
2.7" LCD display |
Display Form Factor |
Built-in |
Microphone |
Microphone Operation Mode |
Mono |
Connections |
Connector Type |
USB 2.0 (5 pin Micro-USB Type B) |
Software |
Software |
Drivers & Utilities |
Miscellaneous |
Included Accessories |
Hand strap, AC power adaptor, USB cable |
Battery |
Battery Type |
Lithium Ion - manufacturer-specific |
Details |
1 x Li-ion rechargeable battery - 700 mAh (included) |
Memory / Storage |
Memory Card Slot |
SD card |
Supported Memory Cards |
SD Memory Card, SDXC Memory Card, SDHC Memory Card |
Memory Card Max Supported Size |
64 GB |
Image Storage |
JPEG 5152 x 3864 , JPEG 3264 x 2448 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 640 x 480 |
Video Capture |
AVI - 1280 x 720 p - 30 fps , AVI - 640 x 480 p - 30 fps |
Manufacturer Warranty |
Service & Support |
Limited warranty - 1 year |
Dimensions & Weight |
Width |
10.09 cm |
Depth |
2.67 cm |
Height |
6.11 cm |
Weight |
127 g |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
0 - 90% |
