Prestigio RoadRunner 505 Dashcam with 16Mb Micro SD
PROTECT YOURSELF FROM THE UNEXPECTED ON THE ROAD!
£44.98
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Real 1080P FHD resolution digital video
  • Electronic image stabilization
  • Motion detection
  • Wide viewing angle
  • High resolution display
  • Type: Dashboard camera
  • Media Type: Flash card
  • Video Input: HDMI
  • Stock Status: Clearance
Product codes
The Prestigio RoadRunner 505 combines high quality Full HD video (1920x1080) with lots of advanced features. High resolution display, easy intuitive set-up and its compact size give you greater flexibility to use under various conditions. A 120° wide viewing angle provides an extensive road overview to record in detail what is going on around you. Together with the image stabilization system and a 10 Mpx photo camera your pictures will always turn out in great quality.
Real 1080P FHD Resolution Digital Video Make high quality video in Full HD 1080p with pure sound and crystal clear images to see in detail what is going on around. The optimal combination of a video processor, three-layer glass lens and supersensitive sensor provides a high image quality even in low light conditions.
Motion Detection Portable and convenient, the device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame. Thus it allows you to save the card memory for a longer video.
Wide viewing angle RoadRunner 505 is equipped with FULL HD-camera with a 120° wide viewing angle. Such an angle is optimal because it provides an extensive road overview, prevents image distortion and does not reduce the object detalization level.
High resolution display It is very easy to customize the image clarity, contrast and color settings with big 2.0-inch TFT screen and LED backlight modules. Adjust the video recording quality as well as all additional parameters and operation modes with the user-friendly control panel.
Product Description Prestigio Roadrunner 505 - dashboard camera
Product Type Dashboard camera - 1080p
Image Processor NT9620
Sensor Resolution 5.0 MP
Lens System Wide-angle lens
Focus Adjustment Focus free
Digital Zoom 3x
Image Stabiliser Electronic
Display LCD display - 2"
Supported Battery 1 x Li-ion rechargeable battery - 450 mAh (included)
Interface HDMI
Colour Black
Dimensions (WxDxH) 8.2 cm x 2 cm x 5.5 cm
Weight 90 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Prestigio RoadRunner 5...
£44.98
