Prestigio RoadRunner 565GPS HD DashCam
Product codes
FUNCTIONALITY AND SAFETY ON ROAD!
This is a Video recorder which takes protection to a whole new level. It allows you to be safe on the road and receive warnings when unitentionally the vehicle is leaving or crossing its lane.
SUPER HD VIDEO QUALITY
Record highest quality Super HD videos with Ambarella A7 chipset, sensitive Aptina sensor, IS and WDR technology. Highly detailed videos can be used as evidence in legal action, and motor vehicle insurance claims to prove liability.
Warns and protects
RoadRunner 565 makes your trips more safe and protects from accidents that can occur because of negligence or due to somnolence. Video recorder will warn driver in case the vehicle is leaving or crossing its lane. (Lane Departure Warning System (LDWS)
Capture details with 10x zoom
An ultra wide viewing angle of 170 degrees and 10x digital zoom enables you to capture every detail in a nearly panoramic view.
Endless recording
Cyclic recording ensures that camera doesn’t stop recording in case the storage is full. Camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely.
256 MB internal memory allows to save recorded videos on device even without SD card.
Motion Detection
The device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame allowing you to save the card memory for a longer vide
G-Sensor for file protection!
G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won’t be removed by loop recording.
Product Description Prestigio Roadrunner 565GPS - dashboard camera
Product Type Dashboard camera - 1296p - widescreen
Memory Card Slot microSD card
Image Processor Ambarella
Sensors G-sensor, motion sensor
Sensor Resolution 3.0 MP
Effective Sensor Resolution Photo: 3.0 MP
Max Video Resolution 2304 x 1296
Lens System Wide-angle lens
Focus Adjustment Focus free
Digital Zoom 10x
Image Stabiliser Electronic
Display LCD display - 2"
Real-Time Locations GPS
Incident Detection G-Sensor
Supported Battery 1 x Li-ion rechargeable battery - 130 mAh (included)
Interface Composite video/audio, HDMI, USB 2.0
Colour Black
Dimensions (WxDxH) 9.7 cm x 4.2 cm x 4.2 cm
Weight 83 g
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Prestigio RoadRunner 5...
